RE: flaky pull start
ok ill sort this out. You put ur buggy on the box and it has a motor, and the motor alligns with the flywheel or "grippy pattern" circle.btw the flywheel is the grippy pattern thing. The motor spins the flywheel and due to some miracle which i hhave no idea how it works, after a bit your engine starts up.Its great.
Ben
