RE: E-flite Ultimate....the new one
Hey, Jet;
I've got mine together, so far. I am using a 11.1 Li-Po 1320 and a Hi-Max 4100 (geared). Where exactly did you place your battery? What is the best CG? Between 90-100mm from top LE? I'm going to fly it with the motor I have on hand right now, but have my reservations already that it will perform only marginal. Should I switch to the E-flite Park 400 Inrunner and use the supplied gearbox that came with the plane? Your help is greatly appreciated. Thanks
