RCU Forums - View Single Post - Double Taco
Thread: Double Taco
Old 10-24-2005 | 03:02 PM
Ed_Moorman's Avatar
Ed_Moorman
Default RE: Double Taco
Looks great. You didn't think about a flap in the center? You don't need flaps, but you might use one in a crow set-up.
I would also think about holding elevator and rudder servo placement until you cover and install engines. You might need to move 1 to the rear for CG.
I found I needed something stronger than HS 81s on ailerons. They just weren't powerful enough.
On my twin fuselage Sky Raider, I used double servos-2 aileron, 2 elevator, 2 rudder, 2 throttle. You normally use 5 so this is 3 extra. I also split my elevator in the center and mixed to get them together a la dual elevator set-up.
Man, it sure would be something to 3D a profile twin. That is one sharp project.
