Cen,
Do you also use one of Vantages' manifolds w/ the pipe or the stock? Im just not a big fan of having a 90 deg. bend in any exhaust system. That definately does not promote good flow and has to cause alot of negative pressure. I feel you on the pipe though, surely that saves a noticable amount of weight. This is why Im leaning toward the CVEC pipe, alot of weight has been added to my truck (alum this and that) and the hope is to get an added boost to counteract. Several buddies are using them on T-Maxxes, MGTs, sedans, etc., and get a considerable jump in performance. The only problem is there is no Genesis spec. pipe. I ordered the new pipe made for the Savage, but the tech. seems to think it will perform.
Anyway, thanks for the reply, anymore suggestions would be great.
