Throttle 'Boost' Function possible?
Hi, Steve!
9C can do this easily. 6X cannot.
For 9C, do a throttle to throttle mix at -10%, on the high side only, with the desired switch as the trigger. This will give you your 90% when the switch is pulled, adn give you your 100% when the mix is off.
