Need help on Tiburon
I bought this from my LHS a couple of months ago and am just getting around to building this. I've run into a couple of problems. It appears as if I have the GF wing but I only have 1 short and 1 long leading edge doubler. The plans only show the std wing and there is no manual for the Tib on the disk. I asume that the .230 Dia. carbon rod must be bowed to fit in the wing slot, is that right? The manual for 300S talks about some plastic shims to use when using a stick mount motor, should I have those shims as the 1/4 plywood mount does not even come close to fitting my gearbox.
Thanks for any help
Dennis
