RE: Phoenix Giles 202
Oh I forgot to add, I put a pin on the front of the bellypan and drilled a hole in the fuse. So the bellypan can lock into position with the pin. The rear of the bellypan, I put a balsa stick on the inside of it so I can stick velcro to it.
so I basically put the wings together with the aluminum joiner, tape it together with 3M electrical tape, bolt it down with the supplied nylon bolts, and finally slide the bellypan pin into it's slot and stick the whole bellypan down on velcro.
Works great!
I can get photos if needed
-Tomi
