RCU Forums - View Single Post - CAP 232 kyosho
Thread: CAP 232 kyosho
Old 11-05-2002 | 09:13 AM
kris1
Default CAP 232 kyosho
Carletto,
I have just set mine up. It will be flying this weekend, weather permitting. I also have the YS 63 in it, set it at 45 degrees so the muffler tracks down the exhaust slot in the fuz. . I am using Hitec HS 525mg for ailerons and HS 645mg for rudder. For elevators I have used a JR 591 for elevator. I am running the radio at 6V. I kept the Y push rod, but have modified it so the two halves of the elevator are working together. I have also joined the elevator halves with piano wire. If you want to put separate servos in for the elevators then you will need to re engineer the tail area, as it built of stick. The inside of the structure will need to be lined with ply. The nose of the Cap is short and you may then get balancing problems. Mine as set up need the battery put hard against the front of the servo tray to get the mid range CoG. Two micros or minis in the tail will need the battery shifting up front, problem is how far?
Good luck
Kris
