If you are using a pull-pull for the rudder and mount the servo in the center of the rails, you might want to consider using the bellcrank assembly from Central Hobbies. THis will eliminate any slop and the differential from locating the elevator servo off center wsith a "Y" pushrod type arrangement.
Bellcrank Link
It's not cheap, but it is very well made and works great!
Jim!
