RE: First kit (2nd plane)
I guess I'll put off flying it after what I read here. I didn't know it was that hard to fly. I'll probably get a big stik arf and fly that while I'm building the kaos. I'm all set up with a building area. I have a door and pink foam insulation as a building surface. I've already started construction. The tail section is done and I've started on the wing. I'll try to get some pictures if I can find my camera cable. What kind of servos should I install in this plane? Are standard servos OK for a 60 size plane? Also would a saito 91 four stroke power this plane ok (I'm reconsidering engine choice).
Thanks in advance for help.
