RCU Forums - View Single Post - KMP B-25 CONSTRUCTION.
Old 10-27-2005 | 10:29 PM
  #317
nchrome
Default RE: KMP B-25 CONSTRUCTION.
A while back some of you were talking about having the noxe gear hang up on the pull pull stearing[:@]. Just take a small zip strip and cut the lock end off and use a couple heat shrink tubing and atatch each end of the zip-strip to each cable. The zip-strip will try to straiten out which will keep tension on the cables which will keep them from hanging up in your nose gears. Also if you are into scale try to make the aircooler flaps around the engine cowel function. I did on my Wing B-25. These open and close with the throttle. Low throttle and they are wide open and as you advance the throttle they close. Realy adds to the scale look of this bird.. Don't realy know why more modelers won't do this with their models. I mean if you can make a canopy open and close why not make the aircooler flaps open and close. This also helps in cooling the engines at low RPMs
