RCU Forums - View Single Post - Exactly how much does a plane cost?
Old 11-07-2002 | 06:26 PM
MacAir
Default Exactly how much does a plane cost?
PaPa,
Okay, I really hate to do this, but here it goes...
09/25/02
• Book: Getting Started In R/C Airplanes... $19.99
• Book: Mostly Mounting... $21.95
• Magazine: Model Airplane News... $4.99
10/10/02
• OS .46 FX Engine w/Muffler... $119.99
• (3) Nylon Props 11x7 @ 2.39 each... $7.17
• Hobbico Avistar II .40 AWARF... $114.99
• HobbyTown Slow-Cure 30 minute epoxy... $6.49
• Great Planes Pro 6 minute epoxy... $6.99
• Great Planes Pro Thick CA Glue... $3.49
• Great Planes Pro Thin CA Glue... $3.49
• Hobbico Foam Rubber... $2.99
• Hobbico #64 Rubber Bands... $1.75
10/11/02
• JR XP662 FM (Air) Radio... $249.99
• (2) Nylon Props 11x7 @ 2.39 each... $4.78
• Epoxy Mixing Sticks... $1.79
• Epoxy Brushe... $1.39
• Epoxy Mixing Cups... $3.49
10/14/02
• Top Flite Precision Balancer... $24.99
• JR Servo Arms (Large) w/Screws... $1.75
• JR Servo Arms (Heavy Duty) w/Screws... $2.50
• GReat Planes "T-Pins"... 2.59
• Medium Grade "Sanding Stick"... $1.95
10/15/02
• Masking Tape... $2.19
• Rubbing Alcohol... $1.19
• 1/16" Drill bit... $0.99
• 5/64" Drill bit... $0.99
• 3/32" Drill bit... $0.99
10/17/02
• Hobbico Hand-Crank Fuel Pump... $15.99
• Hobbico "Field Kit" (Basic Combo.) Includes: Field Box, TorqueMaster LC 12V Battery, 12V Battery Charger, Deluxe Power Panel II, TorqueMaster 90 Electric Starter, Glo-Plug Ignitor... $99.99
• Hangar9 "Z-Bend" Pliers... $15.95
• Du-Bro In-Line Fuel Filter (Blue)...$3.95
• Great Planes "AccuThrow" Deflection Meter... $14.99
• (2) "OS" #A3 Glo-Plugs @ $5.49 each... $10.98
10/19/02
• Great Planes "Dural" Landing Gear... $8.99
• Prather 3' Silicon (Medium) Pink/Fuel Line... 2.49
• Great Planes Adjustable .40-.70 Engine Mount... $4.99
10/19/02
• Lowes: "Channel Lock" 195mm Wire Cutters... $16.95
• "Black Shield" 1/2" Drill bit... $5.78
• #6 Lock Washers... $0.80
10/20/02
• Hobbico "VoltWatch" (GMA/Club Purchase)... $10.00
10/21/02
• Short Hex-Wrench Set... $1.99
• Great Planes Lock-Washer #6... $0.69
• Great Planes Socket-Head Screws 6x3/4... $1.55
• Great Planes "Easy Fueller" Quick Filler Valve... $12.99
• Du-Bro "EZ Connector" Heavy Duty ... $1.55
• Du-Bro "EZ Connector" Heavy Duty 4-40... $1.85
10/24/02
• Hobbico Ball Wrench Drivers (SAE)... $11.99
• "WildCat" Premium Xtra 15% Nitro, 18% Oil... $11.99
10/25/02
• Hobbico Flexable 18" Stainless Ruler (includes inches with 1/8 and 1/16 marks; inches with single milimeter marks to 32)... $8.99
• Midwest Bass Wood 3/16x3x24... $2.23
• Prather 3' Silicon (Medium) Blue/Fuel Line... $2.49
• Bondhus Ball Wrench Drivers (Metric)... $7.20
• Du-Bro Foam (Wing) Tape... $1.70
• Du-Bro "Quick-Fill" Fuel Can Fitting... $8.20
• Hobbico "Exhaust Deflector"... $4.49
10/31/02
• Radio Shack: 30W Soldering Iron... $7.69
• Radio Shack: Soldering Flux... $2.49
• Radio Shack: .050 Solder... $2.99
• Home Depot: 2' Clear Coated 14-Guage Speaker Wire (Power Panel Replacement) @ 0.22 each... $0.44
This total is not complete, but so far is $921.21 (taxes not included).
• "AMA" Annual Membership (or "CMA")... $58
For a "Grand Total" of $1,034.48
This "Grand Total" does not include varying annual club membership(s), not to mention getting the "I wants" for a second plane (which I've already bought a Carl Goldberg "Super Decathlon" ARF)... $359 and then get to buy another (larger) engine, reciever, servos and battery on top of the "Grand Total".
All in all, PaPa... I'd have to say that your $30 isn't going to cover it!
Maybe you should buy a RTF.
Good luck, but more importantly... have fun!
Not included in this list of items, are things that I've already aquired from art school, such as my Xacto Knives, #11 blades, 45°/90° Angles, pencils for marking, drill bits that the "ex" doesn't have, etc...
