RCU Forums - View Single Post - first run
Thread: first run
Old 10-29-2005 | 07:22 PM
yeahbaby's Avatar
yeahbaby
My Feedback: (21)
Default RE: first run
well...I've had the opportunity to run her a few more times since my first post.
starts have been hit or miss, I can't figure out if the ECU is power critical (i.e. needs a fresh charge from the ECU pack every start) or if the propane cannister I was using had only marginal propane and thus delaying the ramp up cycle.
I'm leaning towards the problem being with the propane but thought I'd ask you guys.
the parameters for the engine are nearly at the default setting. the only difference is from the ramp adjust setting which is 75.
how many runs are you guys typically seeing from the stock 1800 mah pack?
do you guys recommend breaking in the pump?
overall, impressions are good. she has great throttle response and is very smooth running. I'll have a better or different perspective once I try to fire her off with a new propane can and will let you guys know.
keep up the good work
