RCU Forums - View Single Post - Mintor 170 Vs OS
Old 10-30-2005 | 12:46 PM
wvr's Avatar
wvr
Default RE: Mintor 170 Vs OS
About the MVVS:
Pipe length is 67cm measured from the start of the manifold to the rough-part on the pipe.
Pipe can be set a bit longer, around 68-69cm, we are trying that now. Our KS1015 has got already a 10cm extenion to the pipe,this was done by Krumscheidt , so I think you can order them like that.
Manifold is a stainless steel one, 'm not sure which brand. The motor is hanging at 7 o'clock, so a simple 90degrees manifold will bring the pipe in the middle of the fuselage.
Fuel is 10% CoolPower (the green stuff)
If you need pictures send me your email
Winfried
