RCU Forums - View Single Post - EVO 58 arrived
Old 10-31-2005 | 10:32 AM
  #39
David_Moen
Default RE: EVO 58 arrived
A 24x10 will give you a bit better mid range "grunt". The 23x10 will spin up a couple hundred RPM higher, but you should take advantage of the engine's power curve and pull a bit bigger prop. The Jtec muffler works well on the 59 as well if you want a firewall forward solution,
