RE: New O.S. 120 AX
The 46 AX has no ring. I wonder if the 1.20 went over to a ring at that size?
As regards the bearings, I make it a standard practice to swap in a Boca Stainless bearing before I run an OS these days. OS tends to use "same" size bearings in a lot of their motors so I am expecting that this will an easy to obtain bearing set.
Regards,
Eric.
