RCU Forums - View Single Post - New O.S. 120 AX
Old 11-02-2005 | 12:27 PM
MicroMac
Default RE: New O.S. 120 AX
A RE 2-stroke would have been nice
Two new options in the 90-120 motor segment before Christmas then.
O.S. 120 AX and Saito FA-125A AAC
O.S. 120 AX
Displacement: 19.96 cc
Bore: 30.4 mm
Stroke: 27.5 mm
RPM: 1800 ~ 9500 r.p.m
Output: 3.1 ps / 9000 r.p.m
Weight: 647 g (without silencer)
Saito FA-125A AAC
http://www.horizonhobby.com/Shop/ByC...rodID=SAIE125A
Type: 4-Stroke
Displacement: 1.25 cu in (20.52 cc)
Bore: 1.24 in (31.7 mm)
Stroke: 1.02 in (26.0 mm)
Cylinders: Single AAC
Total Weight: 24.69 oz (700 grams)
Engine (Only) Weight: 21.87 oz (620 grams)
Muffler Weight: 2.89 oz (80 grams)
Crankshaft Threads: M8 x 1.25 mm
Prop Range: 15x7 - 17x6
RPM Range: 2,000 thru 10,000 rpm
Fuel: 10% - 30% nitro Synthetic mix
Mounting Dimensions: 152 x 60 x 126 mm
Muffler Type: Cast
HP: 2.2
Cylinder Type: AAC
Carb Type: 2 Needle
Crank Type: Dual Ball Bearing
Hmm Just waiting for YS
