RCU Forums - View Single Post - 3D Foamy Mini Sukhoi Build thread!
Old 11-03-2005 | 10:49 PM
john wondra
Default RE: 3D Foamy Mini Sukhoi Build thread!
more
pict 11: after you have mounted the motor use the provided triangles to brace motor to the fuse, Bevel the triangles to 45 on all 3 sides then Wipe with alcohol and glue. Repeat on all 4 sides.
pict 12: Motor instalation: Use the provided Lazer cut motor mound and center motor onto the mount, then predrill the holes to mount the motor onto the mount. Then slide onto aircraft, I recomend 0, 0 motor thrust. glue motor mount to foam once the motor is centered and glue to foam at all 16 glue points where wood touches foam.
pict 13:Here is the vinyl I have added To help keep a little orientation... I like www.badbradgraphics.com he does anything custom and doesnt charge extra to make sure he gets everything perfect, I have nothing to gain by recomending him, just a person ive had a plesure dealing with. More to come....
John
ID:	348407   Click image for larger version
ID:	348408   Click image for larger version
