RCU Forums - View Single Post - Ki t Suggestion
Thread: Ki t Suggestion
Old 11-06-2002 | 03:08 AM
LarryC
Default Ki t Suggestion
If you want to use a .40, the LT -40 would be a better choice. I have had both planes and presently have a tailwheel version of the LT-40 under construction. I think I like the lighter balsa construction of the LT-25 better than tha plywood used in the fuselage of the LT-40, but the 40 is probably stronger.
Either one is a blast to fly, and large enough to be easy to see.
Larry
