RCU Forums - View Single Post - When pinning things to your surface, do you pin through the plane part?? Pls Help
Old 11-06-2002 | 02:29 AM
torque_roll
Default When pinning things to your surface, do you pin through the plane part?? Pls Help
When building a kit, and pinning things down to your work surface, do you guys pin directly through the plane part that you are working on?? Or around it?
Thank you,
torque_roll
