RCU Forums - View Single Post - When pinning things to your surface, do you pin through the plane part?? Pls Help
Old 11-07-2002 | 02:06 AM
TerrellFlyer
Default When pinning things to your surface, do you pin through the plane part?? Pls Help
I pin through some parts and criss cross others,its a builders judgement, when I pin I use a couple different size T pins,if i need some extra hold down pressure,I stick the pin through a button,ta da,now have a large headed pin.
