RCU Forums - View Single Post - When pinning things to your surface, do you pin through the plane part?? Pls Help
Old 11-08-2002 | 02:15 AM
rajul's Avatar
rajul
Moderator
My Feedback: (58)
Default When pinning things to your surface, do you pin through the plane part?? Pls Help
Originally posted by rplumbo
Rocket City makes (made?) these great pin clamps. Here's a link:
http://www.hobbylinc.com/gr/roc/roc55.htm
It's basically a little black disc you put on the end of your pin that uses the pressure to clamp the piece in place. I've been using them for years, and they save so much hassle. They're no longer on tower's website, but you can probably get them from your LHS!
Use 'em, they're great!
Reid
Is Rocket City still around ? Anybody that still sells this pin clamps ? Thanks............
