RCU Forums - View Single Post - When pinning things to your surface, do you pin through the plane part?? Pls Help
Old 11-09-2002 | 12:54 AM
torque_roll
Default When pinning things to your surface, do you pin through the plane part?? Pls Help
When you guys use weights to hold the parts down (ex: Wing Ribs) what weights do you use? I'm in the process of gluing my wing ribs down, and I can't pin through plywood, so I have to use weights. Or is there another way?
Thank you again.
Patrick
