Originally posted by torque_roll
When you guys use weights to hold the parts down (ex: Wing Ribs) what weights do you use? I'm in the process of gluing my wing ribs down, and I can't pin through plywood, so I have to use weights. Or is there another way?
Thank you again.
Patrick
I use T-Pins to hold down everything. To hold a rib down just put the pin up against the rib and use the "T" to hold it down.
If you need real weights, visit a SCUBA supply store
Don
