RCU Forums - View Single Post - FLITON EXTRA ELEVATOR HOLE
Old 11-05-2005 | 12:17 AM
tIANci's Avatar
tIANci
Default RE: FLITON EXTRA ELEVATOR HOLE
The right thrust is built in, just line up the mount and it will be fine. Just remember to line it up slowly so all 4 screws will be spot on. The you need to get the blind nuts in, you can use a piece of ply at the front as you put the screw in to get the blind nut to hold. Even better if you can get a large diameter washer for the screw too.
