RCU Forums - View Single Post - Need help completing an ARF P-51
Old 11-05-2005 | 12:15 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Need help completing an ARF P-51
[email protected],
At first glance this may come off as sounding cold hearted, but that isn't what I intend with these comments. The biggest piece of advice that I can give you for completing the plane you mentioned is to READ THE INSTRUCTIONS. When you have finished doing that then you should RE-READ THE INSTRUCTIONS. Then after that you should go through the instructions again to make sure you understand everything. One of the biggest causes of mistakes when putting together a plane such as this is not completely reading the instructions and following what they say.
We could give you advice here until the cows come home, but we can't even come close to what you will find out from the instruction manual. That's going to be your #1 source for information on what you should do to finish the plane. After you've gone through the manual if you have any questions or don't understand anything then come back here and post your questions.
As I said above, I'm not trying to be cold hearted, but it's really hard for us to give advice like that because it's such a broad area to cover.
Ken
