RE: Install the DEPS elevator system in a painted fuse
Troy,
What are the parts you used to connect the pull-pull cables to the servos? I assume it is some kind of 4-40 threaded piece with a hole for the cable to go through? Do you have adjustments like this at both ends?
Jim O
