RCU Forums - View Single Post - Install the DEPS elevator system in a painted fuse
Old 11-06-2005 | 08:19 PM
OhD
Default RE: Install the DEPS elevator system in a painted fuse
I should have pointed out I switched subjects by specifying I was talking about the pull-pull on the rudder. Many of the fittings that I've used in the past had sharp edges that eventually cut the cable.
Jim O
ORIGINAL: MikeEast
OhD, Its a push pull system. You use the threaded 4-40 CF rod ends on each end with ball connectors or whatever. It is adjustable at both ends.
