RCU Forums - View Single Post - Prop question
Old 11-07-2005 | 02:03 PM
britbrat
Default RE: Prop question
Three blade props are usefull if you need to transmit more power than the available fit of two-blade props can handle (due to prop diameter limitations), but as noted, they are usually a bit less efficient than two blades.
If you can fit a bigger two blade, that is usually the better choice.
