RCU Forums - View Single Post - OK MODEL'S 3d cap need some info
Old 11-06-2002 | 08:09 PM
hilleyja
Default OK MODEL'S 3d cap need some info
http://www.modelrec.com/catalog/item105.html
It is a heavy airplane for a 45-size 3D bird -- mine came out at 7.5lbs. MRC is very adament on not over-powering this airplane. They reluctantly replaced my wing after it split down the middle in flight -- lucky for me I limped it back to the ground without further damage. It was very clear the problem was related to OK models construction and their lack of glue in the wing root area. I had an MDS-68 on it, which was not a powerhouse either (the engine was sick and I eventually got rid of it.)
Both major reviews say the MVVS .49 engine is appropriate. I tried to order one from Morris and gave up after 6 weeks. I now have an OS SX .50 on it and that appears to barely give it enough power for simple aerobics -- not confident it will ever allow the 3D capabilities to shine. (engine still very rich, not broken in yet)
It is expensive for a 45-size airplane, over $300.00. My wife picked mine up from a local shop in Palm Bay, Florida when they had a get-rid-of-it price discount of 30% -- she only paid $245.00 for it. Even that was expensive.
The airplane covering and graphics is awesome. Instead of the traditional heat shrink covering it uses a foam back covering, pre-printed with graphics. ABC plastic makes up a large percentage of the finished edges of the airplane -- for the most part it correctly augments the construction. The cowl, on the other hand, is very difficult to construct -- it is made up of 3 pieces of ABC plastic that you have to cut out of a larger piece. You assemble it with super glue and try very hard not to be messy with it. Any spilt glue turns white against the red background and cannot be removed. I have used oil-based polyurethene to turn the white clear and hope it will withstand the fuel over time.
It flies well but I don't yet have a feel for its 3D capability because I don't yet have the power to turn that feature on.
