RE: Install the DEPS elevator system in a painted fuse
Paul,
where did you get a Carbon Fiber Prophecy? I don't know of anyone that ever produced one? The prophecy was produced by Dixie and then turned into Piedmont and now I think PAC has the molds. Unless somebody made you a special one your fuse is Fiberglass.
I would say you having else going wrong. I would look at another problem...I even run my antennas internally in the fuse inside an antenna tube.. I have flown Futaba for many years until about 99' and then switched to JR and never had any problems with either one. What radio are you using? Maybe you are having trouble on a specific Freq in your environment or maybe there is really something worng with your system. I send my radios in every single year and have them tuned up and tested. Its rare that they find anything wrong. But sometimes a weak output on the module or something like this...its gets fixed and I don't have troubles.
I have always used metal cables...and this combined with CF pushrods on the DEPS system I have never had a problem.
Troy
