RCU Forums - View Single Post - Correct spinner?
Old 11-07-2002 | 09:07 PM
MinnFlyer's Avatar
MinnFlyer
Default Correct spinner?
Lowlander69,
Spinners are made to accept the smallest prop that the MFGer thinks someone will use with it. That way if for some reason you need a large spinner with a small prop, you won't have your little prop coming out of a gigantic hole. The bottom line is: Choose the spinner that is the correct size for your model, and be prepared to enlarge the holes if need be.
