Correct spinner? >
Correct spinner?
Correct spinner?
Old 11-06-2002 | 06:05 PM
Default Correct spinner?
What size aluminum spinner will accomodate a MA 13X6 prop without having to trim the slots?
Old 11-06-2002 | 09:53 PM
Mendes's Avatar
I think a Dave Brown 2 1/2" will (I can't remember what I have). It's either that or the 2 3/4".
Old 11-07-2002 | 09:07 PM
MinnFlyer's Avatar
Lowlander69,
Spinners are made to accept the smallest prop that the MFGer thinks someone will use with it. That way if for some reason you need a large spinner with a small prop, you won't have your little prop coming out of a gigantic hole. The bottom line is: Choose the spinner that is the correct size for your model, and be prepared to enlarge the holes if need be.
