RCU Forums - View Single Post - two questions
Old 11-08-2005 | 07:06 PM
flier
My Feedback: (7)
Default RE: two questions
ORIGINAL: mogley
blenderm tape is a tape flyin tiger used to seal his hinge gaps, see his post. It appears to be some kind of medical use tape from 3 M that is clear and easy to work with.
http://www.rcuniverse.com/forum/m_27...tm.htm#2773490
I will be flying the DA-50 in Naples Florida using the Slimline exhaust. The engine is brand spanking new, run approx. two minutes getting approx. 6600 RPM's now. Using 32:1 mix of Ashless oil and regular fuel. Temperture 80's - 90's most of the time, finally now getting cooler.
I also just purchased the "wingtote" brand for my wings from tower at $ 61 for the small. I hope they are big enough, did messure the wing and it was at least 2" smaller that the spec's listed on the Tower web site.
For hinge gap sealing, I use clear packing tape.
Cheap and goes with all schemes
If your using the DA-50 in a 28% Wild Hare, you've more than enough power to do it all!
The small Wing Totes are just a little too small for the 28% wings.
