RCU Forums - View Single Post - AFP eclipse to 9303 no control
Old 11-09-2005 | 09:13 PM
matt3D
Default RE: AFP eclipse to 9303 no control
Ok, so it recognizes it in the control pannel right? If so thats good, all you need to do is assign the channels in afp. If nothing moves then you need to go to the control pannel, game controllers, then find it and get the window open. I am not sure what exact settings your transmitter needs but this is where you tell it what you want it to do. For me I have to do this . "Then you should see in controllers, USB ADAPTOR, the stats should say OK. Now you need to click on properties, then click on the settings tab and click calibrate. Now you have to go in order by doing what it says but you have to go in order first with the throttle, then elevator, then the rudder. Next, this is the most important; click on reset to default." I made a post saying how to use the game commander. Maybe this will work for your transmitter too....?
Hope this helps,
Matt
