RCU Forums - View Single Post - engine help please.
Old 11-10-2005 | 01:05 AM
JROD96
Default RE: engine help please.
If your motor still has compression check for leaks in the tank or in the fuel tubing because it causes the same problem you describe as well just change the lines it's cheap fix if that's the problem
