RE: Need help completing an ARF P-51
not sure if engine type matters... i m using a magnum .91. i have also put robart air retracts and struts on it. I tried to keep everything over the cg. any way... i don't guess the extra weight will hurt. the plane is level when lifted by the wing tips at the listed center point 4 3/4 inches behind the leading edge. if you have any tips i am all ears.
