Toro 25 prop hub
I am converting 4 Toro 25cc engines. I do not have a lathe, so I need to buy the prop hubs from someone.
On eBay i found this prop hub, but I am a little vorried if it has good enough contact with the flywheel.
The only part toching the flywheel is the back of the hub, but the diameter is rather small.
Has anyone tried this, and how do you make your hubs?
