RCU Forums - View Single Post - Smallest plane i ever seen!!!! Does anyone have this plane?
Old 11-11-2005 | 08:30 PM
Iturnright's Avatar
Iturnright
Default RE: Smallest plane i ever seen!!!! Does anyone have this plane?
Yes, I have one, it is indeed very small. The plane itself is 2 channel, the radio has four channel capability. I suppose the main question is: How does it fly? The answer is that it flies very well for its size. Once it starts turning, it has a very good radius, and the motor has good control over its flight without porpoiseing. With rudder only, turning is a little slow, but since it's top speed it less than a mild jog, and its lowest speed is about sub walking speed, it still can fly in an average living room. Outside it'll fly as long as there is absolutely no wind. As you'd expect, even with the mildest of breezes you'll be fighting with it. However, flying in an auditorium, it would really come into its own. You'd have the room of flying in an open area, and no wind. It is suprisingly durable, as flying in a living room requires, the propeller will go off, as will the battery in some cases, and if it is a very serious crash, the tail beam may break. In all likelyhood, you are more apt to crush it than crash it. Overall, it is such an amazing little plane it is probably worth it. So, if you want a very unique, enjoyable plane, and have some exta money, buy it.
