RCU Forums - View Single Post - Throttle Position Question
Old 11-12-2005 | 10:34 AM
Rodney
Default RE: Throttle Position Question
Kenney4842, your first post is very good, you have the idea correct and are doing it all correctly. True, once you get the engine running you will probably have to make some minor adjustments to get the engine to kill with trim switch all the way down yet get proper idle with the trim in the upper portion of its range. Sounds like you know what you are doing.
