with a P-60 on it and I don't have a problem bleeding in turns
I guess it all depends how hard you want to fly .... mild wide and gentle, and you wont bleed speed on a P60 .. start pulling it a bit harder , and you will .. I like to go near 200, and keep it there through the turns..
A friend of mine just swapped his P70 out to a P80 on his BobCat, and says even that small increast of thrust was a great boost in performance ..
if ou consider the total investment, a few more $ to go from a p60 to a p70 is more than worth it ( if not to a p80 or 120 )
either way, this is one fun plane !
Wojtek
