Originally posted by BernieG
hahum, if you really want to make a scale reno racer, you will have to clip wings "dyssimetrically" (not sure it's a word !), most of them don't have the same wingspan on left and right, as the goal is to loose as less speed as possible in turns, having more lift on the outside wing help to turn (in fact, to bank) with very small control deflection. Now, It would be perfectly fliable as a model, but you have to be ready for possibles snaps at high speed ( if you turn the other way), fast landings, and so on....
Should make a very "interesting" model, if not very relaxing.....
Bernard
First I have heard of that. Do you have the names of the planes with an assymetric wing trim? Rare Bear has the same wing clip outboard of the wing fold and it's the fastest prop plane on the planet. Pretty sure Strega and Dago Red are also symmetrically cut.
Just curious,
Don
To the original question, I trimmed one bay off the old TF P-51 (red box) back in the early 80's. I turned it into Dago Red. It didn't seem to fly any different than the stock P-51B that I had at the time. Just keep the airframe as light as you can if you are going for a major wing cut.
Good Luck
Don
