RCU Forums - View Single Post - Clipped Wing Mustang
Old 11-17-2002 | 01:50 AM
hattend
My Feedback: (20)
Default Clipped Wing Mustang
Here are some pictures of the "Beguine" P-51.
http://www.esparacing.com/aircraft%2...P51Beguine.htm
http://www.pylon1.com/airracers/airc...focus/beguine/
From the Pylon1.com link above:
"The idea that Walter Beech wanted in it was to incorporate the radiators in a wing-tip nacelle so you get a little jet effect from it. All a jet engine is: you build a fire in the middle of a nacelle - by putting the radiators in the nacelles we got a little jet effect and overcame the drag of the nacelles as well as cleaned-up the wing-tips. That was Walter's idea on that. When I told Paul what Walter wanted he said "Well J.D., that's a crazy idea! We ought to sink the radiators in the leading edge of the wing - that would be the cleanest". I said, "No Paul, I want them in a nacelle on the wing-tip. I want you to shorten the left wing 24 inches and I want you to shorten the right wing 30 inches, that's what Walter wants." And so he says, "J.D. you know, that's crazy! I'm going to have to fly this airplane!" I said, "Well, if you don't want to do it pack-up and come on home and I'll send somebody else out there that will do what I want." Paul then said, "Well, OK I'll do it, I'll do it." So he built the airplane with the nacelles."
As for Rare Bear's prop, here is the history from John Slack (from AAFO.com):
Propeller goes as follows:
1969,1970 Stock stock length DC-7 Prop/C&S propellers
1971-aproximately1986, stock Aeroproducts propeller with M20A- 162-0 blades.
1986-1990 Stock Aeroproducts propeller with H20G-162-0 blades.
1990-2002 Highly modified P-3/Constellation propeller.
2003 Thats the secret now isn't it?
As stated before M20A-162-0 blade has the cuff on the trailing edge, H20G-162-0 blade has no cuff. Rare bear has never had a cut down Skyraider propeller.
John Slack
