RCU Forums - View Single Post - MK Kato soft mount for OS 140 RX
Old 11-14-2005 | 09:56 AM
pmr
Default RE: MK Kato soft mount for OS 140 RX
You can get replacement MK rubber mounts. Don't forget to specify the hard type. You could probably order from pro build in UK or singahobby.com in Singapore. I tried making a couple of those mount using different compounds and all were below par. Your best bet would be polyurethane. Another option is the O.S. polyurethane which can also fit the MK mount you have.
