MK Kato soft mount for OS 140 RX
Old 11-14-2005 | 06:24 AM
Default MK Kato soft mount for OS 140 RX
Hello guys,
anyone is using this soft mount on a 140 RX?
I would be grateful to anyone that could give me the measures of the four black rubber pieces included in the soft mount.
Thank you!
Old 11-14-2005 | 09:56 AM
pmr
Default RE: MK Kato soft mount for OS 140 RX
You can get replacement MK rubber mounts. Don't forget to specify the hard type. You could probably order from pro build in UK or singahobby.com in Singapore. I tried making a couple of those mount using different compounds and all were below par. Your best bet would be polyurethane. Another option is the O.S. polyurethane which can also fit the MK mount you have.
Old 11-14-2005 | 01:37 PM
Pmr, thank you for your reply.
I know that these rubber mounts are available as replacement. The problem is that I have a old MK Kato soft mount for YS I think and I would like to use it on my OS 140 Rx (the screws fits ok). So, before ordering them, I have to know if they are good for my soft mount!
