RCU Forums - View Single Post - CMPro Sukhoi SU-31
Old 11-14-2005 | 10:14 AM
tinkicker's Avatar
tinkicker
Default RE: CMPro Sukhoi SU-31
RevGQ
I was wondering how you worked the fuel tank? The tank fits in to the forward bulkhead rather firmly and the tubes stick through the firewall. The neck is not tight against the firewall but it does touch a little. Did this installation work ok for you or does it need to be modified.
I also am moving the engine to 160mm vs the 150 mm specified to help with the CG location.
ID:	354150   Click image for larger version
ID:	354151   Click image for larger version
