Programmer problem???
I sent in my programmer for the update. I just tried to do a program reset with the programmer. During the procedure the servo will not move to its extremes as it use to. As soon as you press the UP/L & DN/R together the screen immediately shows success without doing any servo movement. It seems that the endpoint program still works but I'm unable to do the reset. Am I doing something wrong or is my programmmer buggered up. I've reset and programmed probably 100 servo's with this unit, it worked perfectly before the update. Thanks Walt
