BV F-4 First Flights
The Pegasus HP is now installed in the F4. A little surgery will be required in order to fit in the electric start version into the bypass but as I dont yet have the autostart components the starter motor was removed and it will be operated in air start mode.
The original Pegasus looks like its never been run after over two years buried inside the Phantom.
I'll let you all know how it goes but it won't be short of thrust !
BRG, David Gladwin
