RE: Programmer problem???
Are you suggesting the programmer originally moved the servo output shaft when you performed a RESET? I don't recall mine ever doing that during a RESET. However in some cases it would rotate the output shaft during the "epaneau" function.
Any who my updated programmer seems to update or Reset the servo much quicker than it used to. To validate the Programmers ability, change some parameters like rotation, dead-band or even travel volume, verify the reprogram took effect and then RESET the servo, if it defaults to factory parameters all is well IMO.
