RCU Forums - View Single Post - Programmer problem???
Old 11-15-2005 | 11:06 AM
BBW Walt's Avatar
BBW Walt
Default RE: Programmer problem???
Yes: It says in the manual to disconnect the linkage because the servo rotates close to 180 degrees. When I hit the 2 command buttons simo- the servo rotates to an extreme endpoint pauses and then rotates 180 degrees pauses and then the LCD will show SUCESS...This programmer has done this on every reset I have done before I re-program any Hitec Digital. I will do as you suggested to see if it will default a program I set up. Its a different programmer than it was.....Thanks for the suggestion I'll post what I find, thanks Mike
